Ct 200H Replacing Front Brake Discs.
Hi, I need to replace a broken wheel stud, so I hope someone on here can advise me how to remove the disc so I can replace the stud. I can remove the calliper ok just need info about the disc, undoing the hub nut and what torque setting procedure and what I need to replace e.g. locking tab. Thanks!
8mm bolts to get the discs off using the holes threaded into the disc.
Don't know about the hub. Most new hubs are bolted on from the rear so hopefully you won't need to buy new kit to get the hub off. Your normal 17-20mm sockets should be okay.
No idea about torque specs. You can get access to the lexus tech website for a small fee to look up all the information you need or maybe someone here who already has access may help you.
