Battery Drain
CLUBCAPT
Having had a Battery drain each time i go away or park the car up, once for two days and received a flat Battery for my troubles i have now fitted a Battery isolator onto the car.
Bazinga!! job done. no problem and only £5.99p from eBay!!! if you have a Battery drain try this cheap fix first before you chase the problem around the car.
post-47114-0-78560600-1399571912_thumb.j
Having had a battery drain each time i go away or park the car up, once for two days and received a flat battery for my troubles i have now fitted a battery isolator onto the car.
Bazinga!! job done. no problem and only £5.99p from ebay!!! if you have a battery drain try this cheap fix first before you chase the problem around the car.
[/quote
Two days must be a record I expect it had a number of short runs before that? Mine lasts at least 10 - 12 days... Battery isolator looks a great idea better have to reset everything than come back and have to call out help.
