I do believe you can get into the lense area on the Headlamp from the back ,they are not sealed beams as you can change the bulbs.The quickest way to disperse the condensation would be to remove the bulbs and play hot air into the unit through the bulb holder spaces using a hair dryer on low heat.
There are some snorkels on the side of the unit they are there to vent the enclosure check they are clear with a bit of wire.
