Best Way To Dyno A Isf
Is it as simple as chucking it in 'Sport' mode and planting the accelerator?
Seen some stuff in the USA where read outs have improved by 20BHP over three runs with doing things slightly differently but dont state what.
Stu
most in US claim (IS300 dyno) a reset of the ECU before dyno can add upto 10 bhp to the results this is without doing intake or exhausts mods.. so my guess will be chuck a higher RON fuel, reset your ECU just before the dyno run to recalibrate parameters, activate ECT PWR, stick it in Sport mode and lock it in 5th or 6th gear and floor it..
ECU reset??? Not keen on that. Would need to re-set again afterwards to make sure it knows i dont want to floor it everywhere!
I will have 2 runs so may do that for one of the runs.
Stu
no need to reset after dyno. if you drive sedately for a couple of miles without flooring it everywhere your ECU should retard back from performance parameter to normal.
