Piggy Back Ecu
SParkyWar
Apex'i S'AFC I or II
HKS S-AFR
HKS S-AFR is similar to the Apex AFC in tuning ability, but much better.
The HKS S-AFR has 11 points of adjustment, the Apex AFC I has 8
The S-AFR has 6 more points of adjustment from 650~2000rpm's for idle correction, the S-AFC I does not have this
The S-AFR has a Response Adjustment, the AFC I does not
The S-AFR's 11 adjustment points can be as close together as 50rpm's, the S-AFC I's 8 adjustment points are fixed & can not be changed
The S-AFR has EIDS which correct the Air/Fuel signal so your car doesn't stall or go rich when your Blow Off Valve releases, the S-AFC I does not have this
