if you want to keep your car original and quite then the only option is buy the part from the dealer and have it fitted locally.
There maybe other options such as exhaust outfits cutting/welding something but I cannot recommend anybody
HTH
HTH
Many thanks. Will get onto Lexus Reading. Mike
I will try and upload a photo of my y-piece after it was welded
If it is done right get it welded but if not then someone will quite easily make a pigs ear of it.
Whoever repairs it for you get them to do it in situ because if you try and undo the bolts and lambdas you run the risk of it all snapping and then you willl need new gaskets and the chances are it will probably blow there then when it is put back together
Stainless Steel welder going to have a look at the crack on Weds. If the pipe has to come off are there any gaskets I need to replace?
Mike
Mike, a few of us have used Grove Garage in Hove as they specialise in Lexus, and make their own systems, I had mine welded there. If you don't find anyone it may be worth giving them a call to get a price (they are very reasonable) That way you can come over here and we can have that coffee we never got around to!
Grove Garage 01273 773055
I got mine welded with brand new gaskets and bolts for £20 here in Birmingham
Hello Phil.
I am booked in to a place down Borden way on Weds to let him assess the problem he says he knows the problem having fixed several.
If not I will come down to Hove, we really must meet up for that coffee. Let me see what happens on Weds. I know its difficult for you to be away from home for long so I will come down to you.
Regards Mike
Hi Phil, What is a good day for you? Mike
Had mine welded last June for the MOT and it hasn't made a murmur since
malc
Thanks to Phil "The Acre" I poodled down in the sunshine to Brighton/Hove, to Grove Motors, a place you have to see to believe, was met by Phil in his lovely LS 400, left mine behind for the ex Lexus engineer to work his magic while Phil and I went off to find a coffee house the long way round of course, but who cares when your in such a beautiful comfortable car, good chat on all things Lexus and an hour later we were back at Grove Garage Tele 01273 773055 car was all done 4" section cut out and a new section welded in and we are back to near silent motoring. The price £45. No one can grumble at that.
Once again the power of The LOC strikes again. Cheers Phil "The Acre".
Mike
Glad to have been of assistance, and meet another member.
Actually, it was Andrew "Scribe" who put me on to Grove Garage, so thanks to you too my man!
And Mike, on reflection, I think you're wrong about Bob Dylan!!!
And Mike, on reflection, I think you're wrong about Bob Dylan!!!g
It wouldn't do for all of us to like the same thing. He wrote some amazing songs I just never liked his singing. Mike
