Help With Alloys
Phantomk2k
Hi there.I found this alloy to buy for mi lexus is200 but not know what ET.
http://www.ebay.es/itm/380850714537?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
There are 8.5 front and 9.5 rear.Front tyre will be 225/40/18 but rear?What size for that 9.5?..In mi car (bmw e60) i have 275/30/19 with 9.5J...
Its more likeable to mount 8.5 all around?
I want something like my actualy car,fit pefect the ET :
According to the listing the offset is ET40, but only the 8.5" width is mentioned in the detailed description. You would need to ask the seller to confirm the offset of the rear wheel.
255/35R18 would be the ideal tyre size for the 9.5" wheel.
In the detailed description says this :
4 * 18" Lenso Spec E Alloy Wheels
Brand New 8.5x18" Front 9.5x18" Rear Lenso Spec E Hyper Dark Silver Alloy Wheels.
Fittings Supplied.
To Fit Lexus IS 200 00 to 05.
And also the seller send me a mesage with the et35 front and et40 rear and 225/40/18 front and 255/35/18 rear.
Thats to tight setup?
I think you'd have to roll the wheel arches to make those fit without any rubbing, maybe even roll and pull them.
Ok... so the question is ,for those alloy, witch et fit perfect and what '' J '' ?
