Is200 Idle Speed Adjustment?
jpac
On a year 2000 IS200, the idle speed goes too low at 300rpm and then the engine stalls, especially annoying when coming to a stop at a junction. Is there an adjustment to increase the idle to 600rpm or similar? I read about inserting a washer years ago but I can't find it now. Any other method considered. Thanks.
Idle speed is set by the ECU so not adjustable.
I would start by cleaning the throttle body (google Lexus IS200 throttle body cleaning) and also check all the rubber vacuum hoses for splits or poor connections.
