Gs300 Se To Gs300 Sport
thesmithster
TTE do a couple of different spoilers which should be cheaper. The standard one on the sport covers up the rear brakelight (has it's own one built in) so you either need to disconnect the old one or remove it. If you remove it you also need to replace the whole cover under the rear window as it will have a hole in it! The £650 quote may include the new cover?
The wheels are OZ Salina so you may be able to get them elsewhere. £1200 doesn't seem too bad a price though. Was that for 4 or 5 wheels?
If you spend £25 on GOLD membership you could save over £200!
