No, the buttons for the seat adjustments will be on the wrong side and this may also mean the wiring looms under the seats may also be incorrectly positioned to fit the LHD looms.
The seats if fitted with airbags will also be on the wrong side.
I would image that all this could be transfiered between the seats but would be time consuming and airbag systems are not the kind of thing you want to start playing around with.
I would look for the correct seats for a LHD model which would be 4 bolts in and out and plug and play wiring looms.
Also remember if you do change the seats to disconnect the Battery and leave it at least 10 minutes for the airbag back up system to discharge.
I was going to say the same as Steve.....if the looms are the same in the LHD car and both seats are electric it migh't work.
All you would do is fit rhd driver seat in passenger side of LHD ect. Then airbags and seat belt clips would still be on the correct side.
