Clutch Noise
Luis200
I hav the same problem.
Is the noise occurring only in neutral as mine is in all gears too..
I put a post on here not too long ago and the guys helped me diagnose the problem as being the gear box bearing but I've not yet been to the garage to get it looked at.
I have been to the garage already and is the bearing. But the mechanic said that I shouldn't fix it yet. Just when I need a new clutch unless it gets worse. Even if it breaks down completely dont damage the gearbox at all as it works out of the gearbox. It makes sense. I just adjustes the clutch pedal bolt and the noise stopped.
