AUX in jack socket under the armrest
Does anyone know if this will work ...
3.5mm jack cable terminated with a female USB socket - in this socket can the audio system recognise a USB stick if its plugged in to this lead?
No this will not work as you would need power to the usb stick which the 3.5mm is for an audio signal only. Exactly why an ipod has its own power source ie Battery. Hope this helps.
