Windscreen Washers
Hawk Man
I have had my 52 reg IS200 SE for a month now, but have only just noticed something about the washer jets.
The jets seem to have 3 nozzles in a triangle formation, 1 at the top and two at the bottom. However when I use them to clean the windscreen I have notice that the water only comes out of the top hole and not the bottom two, this is the same for both washers.
Is the norm, or should I be expecting 3 seperate sprays from each of the washers ?
I will try 'pinning' them at lunch time. I just thought it was odd that the top nozzle was the only one that worked on both of them ?
Perhaps they're switched to 'single soopa high pressure jet mode' :blink:
Hmm, wonder if that's enough for them to cut through the windscreen :unsure:
:oops: :iraqi-info-minister:
hawkman
the best way of ensuring the jets stay unblocked is to give them a boost of french air
easyily done just sign up to join the loc on the calais trip
a nice way to meet some fellow members and a cheap day out
not to far for you either
just think of the benefits to your washer jets :whistling:
:offtopic: i know but what the ........its worth a try
