Plp Strut Bar
yemgi
Steve, I'll be at Calais. :ph34r:
Bazza, My car is a left hand drive, you have a right hand one, that's why it doesn't look the same. Steering column on the left produced implementation modifications :P
Gus, Administrator, it doesn't rub whatever I tried to do it (roundabouts or bumps). The front is now really stiffer, it improves handling quite a lot B) Even if it is much more expensive than Cusco ones, it is easier to fit as no mod is needed an the look is so nice :zee:
