Checked out the how to guide which suggests the following to reset ECU:
Remove the 20Amp/25Amp EFI fuse
Remove the 15Amp ETCS fuse
Problem is I cant find these fuses in the engine fuse box. Pull the cover off from under the Battery and nothing seems to relate to the above on the fuse desc under the cover - unless I am missing something (probably am - apologies!)
I had exactly the same problem mate, I checked with the owners manual and still couldn't sort it. I will just disconnect the Battery overnight instead
Sorry for the thread hijack. But would you recommend this to a new owner (second hand)?
I pick mine up on Saturday and was wondering whether I should do this.
Anything other than stereo that needs to be reset if I do? Seat Memory? Key functions etc?
