Is200 Rear Speakers And Amp Question
Hi Guys, my rear speakers gave up so I replaced them with a pair of MB Quart FTA169 6x9" using the 4 ohm tweeter wiring. I'm looking for a slight increase in bass so I asked the local audio guys if I'm able to run a small 2 ohm woofer in the boot wired to one of the remaining original 2 ohm wires, the audio guy said it possible but would need to know if the remaining 2 ohm wiring is mono or stereo and depending on the power of the amp. I did a search but unable to find the amp specs.
The feed is definitely stereo, I have the diagrams for the 8 speaker set-up and the 9 speaker one with separate woofer as in sportcross.
I can send them you if you pm me your email addy.
After looking at diagrams, i could be wrong, looks like two sets of + and negative wires, so common sense would indicate that using one pair would be mono???
If you need diagrams your local radio guy should be able to tell.
