At Last
Fargo
They look great Fargo.
I think they're gonna have to be my next buy.
Did you take the amber lens out?
:hehe: Geofftronics - I like it...Cheers bud......
Yep i took the amber lens out and got a pair of amber bulbs (#T90981-15011) from lexus parts.
Finally fitted my headlights, colour coded and with DDE's
pictures in the dark didnt come out all that , but will try again.. also with some daylight pictures..
wired em (courtesy of geofftronics) so that side lights will turn the DDE on adn when main beam is on the DDE are off.
pics start here
and here
From the photos, it appears the ring on the main beam does not quite fit the top section. Is this normal with the conversion :question:
thats correct, points to remember is that the fiber cables are fead throught the side light hole. and also the rings do not fit uk spec headlights , and and so i have simply glued them in place. SteveAudio has modified his 'bezel' to accept the clips.
