The background light on my AC is not lighting up properly I don't think it's the bulbs, because when I turn the brightness switch on the dash right up there is some light showing,but not the same as the light on the radio display, has anyone had this problem and how did you fix it??
hi
this is a common failt on the Mark 3
The cheap fix is replacing the capacitors yourself - PM Steve
Or what i done was remove the head unit and send it off to car audio repairs in brighton - and the sorted it for £85
