I know this is a total Faux-Pas to put Chinese parts on my quality Lexus however.............
I have just fitted my bonnet struts that I got from China and they are absolutely great
I am really not messing. Even just one of them held the bonnet up really well whilst I fitted the other one.
I am impressed
Ahh you have the MK3 don't you
The part number for yours are 53440-59025 so they are different. I do not know if they would fit
However I will do some digging and try and source a set for you anyway and send over the link
The OEM with the car back in 1998 have probably lasted this long .... 15 years ..... wonder if the Chinese ones will too !!!!
My 1995 car had the front bonnet struts replaced after 15 years too, by Lexus but at a humungous cost I note ............ I'm expecting them to last to 2025 :whistling:
I have non-Lexus struts, and they are okay, a lot cheaper, and having had them in for a year they are a bit temperamental, in that you have to sometimes find the point at which they hold.
They work less well in the cold.
So it tells me the engineering not as good as the original, but I only have bonnet up now and again, and they are still better than a piece of wood to hold the bonnet up
How long will they last me, I would guess 4 or 5 years.
I also wonder if the internal fit is a bit variable whether they will actually loose gas more quickly.
Adam, a couple of hundred pounds if my memory reading the last poor owners scheduling Lexus bills is correct !
There are other posts on here about replacing excellent non-Chinese maybe struts with economically priced UK sourced one's.
The simple fact is that one hardly has to ever have the bonnet up apart from replenishing the windscreen wash bottle ! Everything is dash light intuitive, even the wash bottle too.
And I used the broomstick trick on my first Lexus, a Mk1, for years.
This Mk3 is my 3rd LS in 11 years of magical motoring :shifty:
The supplier I use in China I use for every strut I need as I have a Toyota Sera with gullwing doors too and needed to replace the door struts
Anyway I specify on all of my struts that I want removable ends as the ends that screw onto the body of the car are fixed to the actual strut.
I now have bonnet struts with detatchable ends so that next time I can just unscrew the strut and replace that on its own - kind of like an insert
Well, bonnet struts are not exactly crucial parts, so maybe Chinese isn't so bad. On the other hand, If it was suspension parts, I wouldn't touch anything from China with the proverbial barge pole.
Mine have gone on my car which I think should be replaced soon. But I wish I could have just go a metal bar/stick like the good old days haha
Here here !!!
When I said I use China for every strut I need I meant bonnet boots doors kitchen cabinets them sort
Not the sort that goes in the centre of suspension springs, I would never do that.
I have had a set of struts from the same supplier in China on the doors on my Toyota Sera for over a year and in daily use and they are still as good as the day they were fitted
I am not sure if they are or not. You would have to directly ask the seller.
However, here is the update
One week on and I have not had to open my bonnet for anything apart from to check if the struts held it up !!
At this rate I can see them lasting a very long time
It would appear that the Chinese make pattern parts for almost everything now days the only things not made in China are takeaways but even these have part numbers which need checking for the correct flavour.
23 Chinese Special Pork
42 Chicken with beansprouts
67 Special fried rice.
I bought my struts from a company in China but they were actually sent from Kuwala Lumpa !!!!!!!!!!!!!!
Arr but were they made by Umpa Lumpas in a chocolate factory?
  • 1 month later...
Got some from eBay recently and fitted in minutes.and the bonnet now stays up and no creeping.
And they are made in the UK B)
Yeah you are right
That stamp was definitely made in England !!!
Seriously the stuff from China is getting much better these days so I am not too fussed if its from China
However they do look pretty good
Yeah you are right
ruts
So how much were the Chinese struts ?
Yeah you are right
ruts
About £35 for the 2 delivered so its not too bad
Yeah you are right
ruts
Good price :) but i was doing my bit for the UK economy :rolleyes: at 52 delivered
That not too bad at all however I know of a few people that sell things on eBay saying 100% uk and they are not.
But there are a few ways to look at it. You were either stitched up by someoe who bought them from china and put a stamp on them (the markup difference between mine and yours is about right) or they genuinely did come from England
the bit from the economy works both ways. If they are from englad great. If not you have kept an importer in a job and off the dole. So kudos for that :-P
