Rear View Mirrors
pheobe
Any thoughts on why my mirrors have stopped dipping when reverse is engaged, they were working when I left home for a MOT but had stopped when MOT was completed was in attedance through most of test so I don't think anything was done that should have affected them just coincidence or what?.
Re previous topic still not got to the bottom of the p1651 alarm yet.
Eric
Check the position of the switch - maybe the garage changed the position since it doesn't work if the setting is not on either left or right. I.e. it doesn't work if the switch is in the mid setting. At least that's what happens on 450h
Don't you just feel a right lemon when you miss something as simple as that :oops:
Thanks for that Kevin.
I don't suppose you have a quick fix for my other problem.
thanks again.
Glad to be of assistance ... I am sure you will find some blue tablets on the net that should fix your other problem. ! Cheers Kevin
