Is There A Headlight Removal Thread?
As per title, I need to remove one of my headlights to replace the ballast.
Is there a step by step guide showing what bolts and screws are where etc.
Cheers carl
If am not mistaken you will need to take the front bumper off before you can take off the headlight.
Correct, remove front bumper and then there are a few bolts holding the headlamp in. Remove these and disconnect the connector and then slide the headlamp out.
