I have had the Battery disconnected on my car overnight while it was in a garage. I have reset the windows which was easy enough but are there any other things I need to reset etc (apart for the clock)
I believe this will reset the ECU - would this explain the car being a bit sluggish while it "learns" the driving habits once again?
Also the Battery terminals are also dry (positive and negative) should these be coated with a lubricant (Vaseline etc) or are they ok to be dry?
thanks
After disconnecting Battery, all you need to do is re-sync the windows and set the clock again. The sluggishness is because the ECU needs to re-learn your driving style. Dont be too gently with it otherwise it will re-learn to be slugglish :) on the Battery terminals i put some silicone grease (very little, vaseline will do the same) but not on the contact itself (didnt want it effecting the contact) just applied a very little over it after connecting it so that moisture doesnt get in
Thanks James
Also lost the CD titles in the display which was not an issue - just selected each again. Sat Nav previous destinations were also lost
