Malfunction Indicator Lamp
hi im new to the forum I have a lexus is200 2003 model the malfunction indicator light came on today as I was stuck in traffic the car started to not run good it was like it wasn't ticking over correctly my petrol was low at the time on the red light so I went to fill up thinking it was a fuel problem but the malfunction indicator light stayed on and its a bit better but still not ticking over right is it a filter problem??? any suggestions????
Hi and welcome.
You need to get a diagnostic done. The car needs plugging into an obd2 fault code reader. Doing anything else at this point is pure guess work. You have to start there.
Lexus charge about £50 for a diagnostic, local garages will be a bit cheaper. Alternatively you can buy your own code reader for about £20 from eBay
