Suspension Top Mounts
asharb123
My car makes a knocking noise when it goes over a bump on the driverside when I bought it. The front shocks had been changed by the previous owner. I've had a number of things changed on the car because they needed to be done, like the front lower ball joints, front drop links and track rod ends and I had secretly hoped this would have also cured the problem. I don't really know what else it could be. Its just annoying more than anything. I've been told there is nothing really wrong with my car and should stop thinking about it.
Any suggestions?
Thanks for the information. The car is going in for an MOT early next month and I will get them to check the top mounts, upper ball joints and arb bushes.
Sorry what are arb bushes and where are these on the car?
Where did you get your upper ball joints from, was that £29 for the pair?
