Interior Lamp Will Not Turn Off
Hi Guys, I'm having some problems with my interior lamp. It is refusing to turn off. I have tried the following:
Switch to 'door' position, close all doors and lock the car. The lamp stays on.
Switch to 'off' position. The lamp stays on.
Disconnected and reconnected the Battery and re-tried the above. The lamp stays on.
I've seen a few other threads on other forums talking about faulty door latches but surely this cannot be the case if it will not switch off even when put in the 'off' position.
I've removed the bulb as not to drain the Battery. Any ideas?
