Worry Free (!) Driving Now New Cambelt Fitted
Just picked up car after having new cam belt fitted, so no more worries as I did let it go 4K past recommended mileage and the old one was 8 years old. Though the garage said it looked in fair shape.
Had it done at Gas & Go in Swindon, and was amazed to only pay £267 which was cam + auxiliary belt. No need to tensioners etc, and as the guy is ex-Lexus dealer mechanic and a GS430 driver felt in safe hands. One of the tidiest workshops I have seen in a long time as well
So if anyone needs a new belt and can afford the rail fares on First Great Western (Gas and Go is a 5 minute walk from Swindon Station), then might be worth checking them out.
http://www.lexusandtoyotaservicing.co.uk/Colorus/colorus/cambelts.html
It was some other member who recommended them to me, and they will be getting my business for the future.
Apparently they are also into bike racing, but two wheels with an engine seems unnatural to me!
I may bear them in mind. The guy I use is Lexus trained and he also said replacing the tensioner etc isn't really necessary. Was there no mention of replacing the water pump, and do they do it in a day?
Basically they said they would replace what needed replacing, and said they would advise me if anything other than belts needed doing.
They did do it in one day, but they preferred me to let them have it for two days, just in case, which was not a problem for me. Looking at the time charged, they took 3 hours to do the job, so no reason why if no major hiccups they could save you a return trip.
Mind you there is not a lot to do in Swindon, unless you take a bike and go off and do a bit of exercise on some of the old railway cycle tracks
They also seem to have a bit of sniff about to see if anything else (non cam-belt related) needs later consideration.
Thanks, I may give them a go. I've been quoted £530 with new water pump and tensioner etc.
The price of cam belt replacement seems to have gone into free fall. Mike
Perhaps they only took of the belt covers,cranked the engine over and sprayed the belt with fresh black paint! :) :) :)
Nah but three hours is good going, is there less to strip out on the 430 engine than the 400 then?
