Picked up my new LS today. She runs as expected. Wonderful. One or two annoying niggles. Right hand wing mirror won't adjust properly. And washer says I need washer fluid, When I don't. but these are common problems I have seen. Hope the photos come out okl. Tompost-43837-0-62438900-1376239129_thumb.jpost-43837-0-22991000-1376239153_thumb.jpost-43837-0-39888500-1376239182_thumb.j
Very nice , bought a set of those wheels of a friend refurb with nearly new tyres and original Ls400 toolbox , for 300 pounds , will then refurb mine and put them on the 99 reg.STILL LOOKING FIR A CENTRE AIRVENT FOR THE 99?
I cant believe how clean it is , I need new arial , work on front suspension, having the paint corrected, got the wheels, some leather work , and sat nav did not work from day one. but I love it , every day use as is the black 99 the missus drives.
Tom
The empty washer bottle light on dashboard is a common fault.
Fix; remove sensor from bottom of reservoir dry out in your airing cupboard test in a bowl to see if it floats to top of column,spray with clearcoat laquer (this stops it becoming saturated again) .replace and jobs a good en.light goes off.
