Automatic Gearbox
Kyle_tt
If it's the Aisin A340 transmission then yes, you can uograde the torque convertor to a higher stall rate and fit modified valve bodies.
http://www.importperformancetrans.com/catalog/toyota-lexus-modified-valve-body/ipt-modified-valve-body--toyota-4-speed-rwd-and-4x4-if-you-cannot-find-a-shift-kit-for-your-a340-click-here-1791.html
I'm really not sure what the gear box is sorry. Where could I find the upgrades to make the changes quicker? Titan motorsports do an auto gearbox bug I sent on the website and its all in Japanese
You need to know what transmission you have fiited in order to even begin looking at modifications, try a google search to confirm it is an Aisin 340.
Again by searching I found the link below but you will have to make some effort yourself :)
Thanks very much for the help really appreciated. I've tried looking on google but the best I've fount is that it says its a R154 but I'm struggling to be honest with you. What should I type in the search bar on google for the best results? "Gear box models for 1991 soarer"
I've fount something that says there's a A341e gearbox that was in the v8 soarer but was also put on the 1jz engines in the chaser and cresta. Do you think it's this one?
