Which Spark Plugs And Where From For Best Price?
rufus36
I've just done the air filter, oil and filter and pollen filter.
I've ordered the 3 belts other than the timing belt(there is an aftermarket Gates one fitted so i'm assuming its been changed?).
So last thing on the list is spark plugs.
Bosch are cheapest it seems but some don't like them?
Also there are obviously Denso(omg expensive!!) and NGK.
So which should i choose and also is there anywhere that is significantly cheaper?
Ta.
PS. Its for an IS200 :whistling:
Personally I would get the best you can afford because its not something that gets replaced that often. At least you don't have to get 8 of the things!
I see you can pay up to £20 each for Denso iridium depending on where you go for them :crybaby:
What do other IS owners recommend I wonder?
A set of Denso/Toyota ones can be bought on eBay for about £55-60. Getting the NGK variant (IFR6T11) instead, will save you about £20.
I replaced my plugs earlier this year - NGKs out, Densos in, and I can't say I noticed any difference so I would recommend NGKs.
A set of Denso/Toyota ones can be bought on ebay for about £55-60. Getting the NGK variant (IFR6T11) instead, will save you about £20.
Me too. I bought NGK iridium plugs, they cost me around £70 for a set of 8.
