Hi
Got a squeaky wiper motor mechanism , light oiled what I can see , but still doing its squeak . How do you get to the wiper motor and arms ? Any ideas :-)
Jon
The wonders of a service plan with the supplying dealer - such minor irritants are usually dealt with without charge.
Argh , that's all we'll and good , but car is well out the main dealer network and is 8 years old , oiled all parts that are Seen but cannot access the linkage under the scuttle , so before I start pulling at parts etc i thought I would ask how :-)
Jon
You have to remove the two wiper arms. Then you have to remove the whole plastic cowling under the arms to gain access to the motor and linkage. It is a bit of a pain but at least the cowling is plastic held in with clips. I think there is also a bonnet seal along the edge which needs to be removed.
The mechanism has a few pivot points and a spring etc which could be the cause of the squeak.
  • 3 years later...
On the back of this, my driver wiper creates a squeak when it reaches the lowest position.
I changed the arm and blade for a new Bosch Aero, cleaned the screen with rubbing-alchohol.
But there is still a bit of a squeak.
Any more thoughts? Use vinegar?
Something else.
( Or just turn the radio up ?! )
