Radiator
Just to expand on Martin' reply..........The level is topped up using the expansion tank (frosted white container) at the back of the radiator, not that easy to see the level lines btw.
The metal cap is used for initial filling of the system normally. So if it's very low, you'd want to fill there first. Then top the expansion tank at the rear of the radiator up to the correct level.
If your level is dropping, they seem to be at the age where the radiators are failing at the moment.
