Anyone Got A Lpg Converted Ls For Sale (Or An Ls To Convert)
Heres the Update,
Thanks for the images my plug is in a worse condition but otherwise similar to the pictures you posted ill try and insert the image at the end of this post.
Ive had the helicoil and compression tests done, dismayed at the compression test results in PSI they are as follows:
windscreen end
190 psi 180 psi
145 psi 180 psi
155 psi 180 psi
155 psi 200 psi
As you can see all the left Cylinders look to be poor, Lexus engineer states they are in spec However the spec shows the min expected pressure to be 143 psi, and its 145 in the affected cylinder ! The fitted plugs were NGK bkr6eix-lpg 4 of em look to be in similar decent condition but the others while in tact look different.
The repair with replacement plugs and a single replacement coil was £850
the diagnosis was incorrectly fitted out of spec plugs, but having driven the car back from the dealers as soon as it switched to lpg the engine management light came on which i wasnt expecting, its going back tomorrow to get the fault code read.
how do i post the image(s) ? (Pm me an email address and ill email them if interested.)
http://imageshack.us/photo/my-images/824/w27g.jpg/
http://imageshack.us/photo/my-images/811/7k6s.jpg/
Regards
Colin
That does not look good Colin - looks like a lot of work needs to be done on the head(s) - that will cost a lot - bad luck - it may be cheaper to put in a replacement engine.
Bren
