Abs Pump Woes
Frosted
Just wanting a bit of advice is possible.
I have sc430 which has been diagnosed by toyota croydon as having abs sensor in pump not working thus giving me all sort of lights on the dash, specifically pretty much all I believe. They want £2700 to replace it.I rang ecutesting and they told me they never heard of it and asked me for the part number
Just wondering if anyone can help me with
part number for the abs pump
part number for the abs module
are there any other cars that that use the same pump
has anyone ever reconditioned theirs
any sort of advice welcomed
Made a few calls and it seems the cheapest I can find is £1700 from a toyota parts store or £1100 for a reconditioned unit from 247spares. Im hitting a brick wall as searching for the terms lexus sc430 abs pump, as most are US hits.
Wednesday its going in to indy to remove the abs pump so we can get the part number, yes that is what I have to do
Thanks in advance
Pump part number as follows
47960-30030 Pump Assy, Brake Booster £1250.00.
Have the Nitrogen accumulator checked as these cause problems on other models if the pressure falls.
Just check to see if your brake lights are working.
Have a look on eBay under sc430 ,there's a breakers yard in Bolton scrapping one ,they might still have that part ,its an 05 plate it might save you a fair bit .I'm sure they could post it for a charge.worth a call .
Thank you, I shall start ringing around at lunch time. I spoke with the breakers yard that have that grey 05 on eBay and they told me that the ABS pump is the first thing that went.
www.ECUtesting.com still cant find the part with that number and bba reamen said that the booster unit is not the abs pump itself. Think ill have to remove it tomorrow and send it to them. Has anyone dealt with them by any chance ?
Should teach me in future not to trust anyone grrrr.....
  • 5 months later...
Update
Bought Used ABS unit 2 weeks ago and gave it to the mechanic to fix, when he romoved the old unit he noticed another wire which was unplugged. Re conected it and behold its working fine.
Im happy on one hand but really ****** off with Jemca Croydon.
Anyway, I shall be keeping the other unit as spare or for sale if anyone gets in the same position
From my reading apparently the unit from the ls430 also fits even though it has a different part number
Mike
More bad news about inadequate dealers who don't look after the customer... I just dispair at the lack of professional behaviour by these garages. In they main they are staffed by monkeys. Ps thanks for updating us on this one it sounds worth knowing about..
