Hi ive had my lexus stood up for about 3-4 months and it was left with minimul fuel (approx 4-6 ltrs ), after puttting it back on the road it started first time like a dream. i went to take it down the road and it started to miss fire real bad, i put it in the garage and they changed the plugs and no probs on the diagnostics. it is now revving up and ticking over fine but has no power, the car is totally gutless i can barley get 50mph up the slight hill near me when i would of usually got near the 80mph mark !!!! some1 has told me it might be the clutch slipping even though u cant hear it or really feel, he said the power is there it just cant get it to the road........any ideas please folks :-) :whistling::whistling::wacko:
if the clutch is slipping then when you put your foot down in gear the engine will rev up without the speed increasing.
are any warning lights coming on?
Hi Colin sorry only just got back to u, I been away !!! The car revs up fine but can't really hear of feel it slip !!! No warning lights either if I try to pull a wheelspin I can smell the clutch very faint so do u think that could be a sign its on its way out :-(
at 30mph in 4th or 5th what happens if you put your foot right down? I would expect slow acceleration along with a slow rise in the revs. If the revs increase quickly then the clutch is slipping.
  • 4 weeks later...
Had the same problem on my gs, turned out to be the bottom catalytic converter
  • 1 year later...
  • 3 months later...
Hi ...as you mentioned the car was parked for 3 4 months. .my instinct says it could be fuel itself. ..or you should get the pump and fuel filter checked.
If fuel is no good car wont rev..and You may also hear the whistle kind of sound when you accelerate...which indicates air trapped in fuel system. Get the fuel pump checked.
