Lexus Parking Aid Lpa400 Help Required
The rear parking sensors on my recently purchased IS300 Sportcross don't work (no sound at all) and I'm trying to find any information about them, the sensors model number is LPA400. Any advice, wiring diagram, fuse/relay location etc would be welcomed.
One last thing, the sensor handbook mentions an optional on/off switch located in the boot, I've had a good rummage but found nothing, does anyone know where this switch is normally fitted?
  • 1 month later...
Now solved this problem, turns out I do have the optional on/off switch for the reversing sensors. It's to the left hand side of the rear of the boot but when in the off position it's really difficult to see as it's black, only shows red in the on position.... now beeping as they should :)
