Rust?
The gs I recently bought has zero rust on it. Is this common? Do even the old Lexus' just not rust? I have never known a 14 year old car to not even have just a little bit right under a arch or something but this is immaculate and never seen a body shop.
Just wondered if this is usually the case?
If cars (not just Lexus) are well looked after then it should not have any sign of rust.
Niall, I doubt you would find rust on even a 1989 LS400 either ........ if you can locate one that is !
Might be very hard to locate. The LS400 wasn't introduced to UK until 1990 so if you found a 1989 LS400 it would be an import.
Mine's the same as Chris and Pete.... but wish I could say the same about Lexus's wheels though :ph34r:
Ar but the wheels still don't rust they just peel and corrode!
It's only the scabby wheels that are an issue, oh, and also the stupidity of not making ( on the LS400 ) the entire exhaust from such high quality stainless steel ... those Y pipes and flanges are a bit of a letdown, but only after 18 years or so I guess.
And that dreadful situation is possibly acceptable ...... as all other cars would have had at least one whole new exhaust assembly by then I surmise,
