Crazy Temperature Gauge
arjohn13
Hey guys,
I have a 2001 Ls430. This what I have had done:
1. Replaced the water pump, thermostat, hoses, cool temp sending unit(2x- oem), and had the radiator flushed.
2. I have no water in the oil(to check busted head gasket)
My temp gauge constantly fluctuates....Ironically, it runs 'rougher' when the needle drops down to cold(even when I'm on the freeway at 60 mph.
When it the needle goes back to half way mark the car runs cool.
This all started after I had everything change. The 'pigtail' did break off the cooling sending unit and the mechanic used another one and sliced the wires together.
Also, when the needle is on 'cold' and I hit the gas on the freeway I hear a 'rattle'(sound like a noisy lifter)
Any thoughts?
Could the gauge be bad? Can I reset it? Could the "crossed" the wires when he spliced it together?
I had the radiator flushed today and the mechanic told me he never seen that much air in lines.
