hello people on the forum -
water pump by pass pipe leaking from o ring behind the water pump.
does the water pump have to come out in order to change this part ?
IS200 auto
cheers :phone:
This can be done with the water pump in situ? You will need to undo the bypass outlet on the head which should let you remove the bypass pipe. You will need two new orings and bypass outlet gasket and best to get a new bypass pipe.
  1. Drain coolant to below water pump level
  2. Undo two bolts holding bypass outlet
  3. Gently prise away outlet and bypass pipe
  4. Clean both o ring surfaces and gasket surface
  5. Replace o rings and gasket
  6. Torque outlet bots to 9 N.m
I have the whole kit new on order.
many thanks dewfallsuk - great help -
