Have just bought my Is200 today,and it has the Beige coloured interior,unfortunately the centres of the seats have a few marks on them.Can anyone suggest whati can use to clean the seats
Cheers Paul
Hello and welcome to the LOC
Either have them cleaned profesionally by a good valeting company or if going the DIY route try some 1001 foam cleaner,you add it to a bucket of warm water then froth it up into a foam,dab the foam only onto the affected areas and then wipe off ( Full instructions on the bottle).
You could also use one of the wet and dry vacuum cleaners such as a Vax.
Results are dependant on your own skills of course and start with a piece out of sight to make sure the colour is not affected.
  • 1 year later...
  • 3 years later...
I use Autoglym interior cleaner. On areas  which are quite dirty, the alcantara looks shiny so to speak. Autoglym did not work, but I'm afraid I'd ruin the alcantara if I try other products.
On alcantara - any kind of fabric shampoo or carpet shampoo
I use Autosmart Brisk for cloth seats - leaves a scent behind as well.
An APC would be fine as well tbh
Just make sure you do the whole seat and not try a spot clean - follow it up with a steam cleaner and leave to dry
