Lightweight flywheel
a light weight flywheel will improve acceleration ,because ther will be less mass to spin up initially,however it will also make stop go driving a pain as the lighter flywheel will also slow down quicker aswell making juddering crap gearchanges
but for acceleration its a good addition
It will make a big difference on hills as well. The car will lose speed very quickly when going up hills with a lightened flywheel. Well the Altezza did in Grand Turisimo 2 anyway!:smilegrin:
Because the IS200 is relatively low on torque anyway (195 Nm) I would not recommend installing a lighter flywheel. You won't have any grunt left.
If you have the TTE kompressor the lighter flywheel should be perfect because there you have enough of everything.
