Power washed first then used poor boys light swirl remover applied by machine, power washed again then polished waxed and sealed took 2 days but car looks brand new again, only down side is neighbour wants me to do his now lol
Looks fab. Hopefully you've dished out the sunglasses for all the nieghbours, you don't want them blinded by the flashes of light as you go past!
Just a point but tyer manufacturers recommend that you should avoid power washing the sidewalls & no I don't know why either
they put chemical in power washers that corrode the alloys, you'll sometimes see cars that arent even 5 years old with flaky wheels. this is why....
Yep every lexus lol
Ps I don't use a detergent thru my power washer... And alloys always hand washed as I have noticed lacquer peeling off
If you check out the link I posted you'll see there's a more serious possibility of causing a blow out
Nice job, car looks stunning :)
Out of curiousity, is your plate private or were you lucky enough to get a normal reg with LEX as the last three letters?
With regards to the high power washers, I've been using one on my cars for the last 15 years. I've never had any issue with corrosion, even Lexus wheels. I believe Lexus wheels corrode due to the type of alloy Lexus use mixed with the heavy salting of our roads in winter equals corroding flaky alloys. Also it stands to reason for me that you don't hold a high pressure washer next to your tyres. I turn the nozzle to spray not jet when doing the wheels, I stand well back when spraying them and finish them by hand.
Chris.... It's a P-plate .....sons names KYLE and cars a LEXus hence KY --LEX and just by luck he's 8 lol .no I'm not buying new car n plates every one of his birthdays lol
