Centre Forward Upholder 'box' Is Jammed Shut.
I had an almost similar problem - rather than jammed shut totally, mine became difficult to open (it would take 5 or 6 attempts or even more sometimes). I resolved the issue with a spray of WD40 on the hinge points - i used the little plastic tube that comes with the spray can. I am not sure if this will work for you, but it is worth a try.
Jesus, this takes me back. Going along motorway, late for a job. Need fuel badly. Put credit card on cupholder lid to remind me (lid closed). Pull into petrol station, card slides forward and falls in the gap (where the lid slides into. ) spend next 30 minutes on forecourt wripping apart cupholder. It's a bad design. I've lost many coins down there as well. I still have only a metal bar over the holders, which is the bracket that supports the sliding lid. It is jammed stuck. Looked for a new centre console a few times, will get it done one day.
