Dash Cam
Lexmanic
geoffers thats great many thanks,im assuming you have mounted it in front of the rear view mirror?
what type of sd card have you fitted,ive been told that its better to have a higher tranfere rated 1 then the crud they sell everywhere in the supermarkets etc.
think im going to get a 16gb class 10?
Yep - just behind and to the right.
I've used a 16GB class6 on those videos so a class 10 will be more than adequate.
I don't think you need a sign to define if a yellow box is in force or not - if it's painted on the road, it's in force, and if it's not in force then it's supposed to be removed (at least, as I understand it)
???? You want proof? I'm not getting into that sillyness. There is a lot going on on that road and its changing weekly at the moment with all sorts of temporary lights, signs, etc. because of new housing estate being built while demolishing the school and completing Tesco's. The residents are in arms over it and its always making the local papers. It just seemed quite clear that day.
Calm down, I did say "as I understand it"...
