It is also the brake fluid level warning lamp.
For the bonnet, check the lever fully returns when you pop the bonnet, other than that, I would check and grease the catches.
awesomeess! cheers man!
p.s what bulbs do they take is it H7...
Hi, what Tigerfish ment is that the low brake fluid light is the same light as the handbrake light, so if your brake fluid is low the handbrake light will come on, it could also mean that your front pads are low.
yeah i knew what he meant it was just a different question lol on bulbs
Gen 2 GS's don't have electric pad wear indicators, only the metal spring clips that scrape the disk and make a racket when they get too low.
