Ct200H Reversing Lights
marshy37
32led running lamps
A q5 Cree LED bulb is a lot better than a 32 LED bulb. I don't think any of the Lexus vehicles have CAN BUS so there shouldn't be any errors on the dash. Makes sure you do both sides at once and only check the bulbs out then. Otherwise one side will draw more current than the other and may confuse the ECU and trigger some safety crap.
