Is200 Subwoofer Question
The standard stereo doesn't have an RCA or line out's. After thinking about adding an active sub to mine, the best advice, since I want to keep my full standard set up, is to tap into the wiring for one of the rear speakers, and run it either to a high level input on the amp, or use a line to RCA converter.
Changing to after market headunit will require bypassing the standard amp with a specific harness, and a bit of a rewire to get all 8 speakers working (it's a bit of a headache as far as I can tell because the speakers are different impedance's)
