Exterior Window Weatherstrips
My 2001 LS430 has been sitting unused in my garage for the last 6 months. After charging the Battery (and insuring the car) I took it in for mot. Needless to say it flew through with not even an advisory.
One problem - when winding down the front windows the weatherstrips didn't take any of the rain off. They are dried out and hard. Does anyone have an idea on what it will cost to replace them? Is the dealer going to be the only option?
Regards,
Liam
seems about on par with the £128 for each tyre pressure valve !!!
Apparently they have now come down to £55.00 each plus a seal kit at £7.00 each.
Telephoneman please allow members time to answer as we don't sit on the forums all the time and also may not know the answer ourselves. :D
Try contacting member ACLex he is the Club's Official dealer and may be able to get you the parts a little cheaper.
BTW are the seals made of rubber? I just wondered if there may be a restorer available which may swell the rubber and provide a better seal.
