Photos Of None Console Lighting
hi
i have never read about this sort of problem
the gear surround is easy enough to remove - just start lifting it at the cup holder end - unscrew the gearknob - and then disconnect the connectors at the back before removing it completeley - then have a look underneath - hopefully you will be able to locate the bulbs - my guess they are 504 or 286 bulbs
hope this helps
