Lowering Springs
Redderz85
I think the lowest you can get is 50mm - to go lower than that you will need coilovers. Bear in mind that for 40-50mm you'll need new shock anyway, as they won't handle such a drop. Also you'll have massively bad camber, you'll need a camber kit and a full geo set up to make it drive properly
