Could anyone help. When turned my heaters up to full with just windscreen de-mister, it just blew freezing cold air. Even after about 5 miles. Would not blow hot at all. When I turned off heater, then put onto auto it blew hot. But always blows cold on windscreen de-mister. Am I doing something wrong. Any ideas??? Thanks
hi
thats how it works - the front screen demister turns on the aircon and directs air towards the windscreen (aircon air is dry air therfore helps clear the windscreen)
You wont get warm air untill the engine has warmed up sufficiently
Normally i use the demist function for about 5 mins or so and then switch it off
HTH
